ZYXEL GS1920-24HP, problem NTP
finally it works !! It was a firewall issue !
thanks a lot !1
Checklist for the NTP implementation for Network equipment.
- take note of the NTP server URL
- take note of the NTP server public (or private, if you have some in your LAN) IP address
- if the NTP server is in the same subnet, a gateway for the IP configuration of the switch is not necessary
- if the NTP server is outside the subnet of the switch's management network, gateway is mandatory
- set the NTP server address (FDQN)
- save configuration
- reboot the switch
- if time do not get correct in 2-3 minutes from the boot, check if the DNS server is correctly setup on the switch
- if the switch still cannot solve the FDQN, set the NTP server address (IPv4)
- if still time is not updated verify firewall rules
out of that... you need some expertise?
Unfortunately, the problem persists. No way to synchronize with the NTP server. I tried via FQDN and public IP.
Do you have an idea of the problem related to the manual configuration?0 -
thanks a lot !1
- 439 Beta Program
- 2.8K Nebula
- 203 Nebula Ideas
- 522 USG FLEX H Series
- 330 Security Ideas
- 49 Wireless Ideas
- 289 Service & License
- 4.4K FAQ
- 98 Security Highlight
