switch password
Saravut
Saravut Posts: 1 image  Freshman Member
edited November 2023 in Nebula
I set up my GS1920 via and android app, but when I login using IP address on PC the admin/1234 won't work what can I do?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,623 image  Zyxel Employee
    Hi @Saravut,
    Welcome to the Zyxel community!
    Since your switch is controlled by Nebula, the switch will apply the site-wide password.
    You can reference this topic.
    Hope it helps.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Saravut,
    Hope it helps.
    Zyxel Melen
Nebula Tips & Tricks
