ZYXEL USG FLEX 100W Log Display Options
Lost1
Lost1 Posts: 33 image  Freshman Member
I don't know when this changed but when looking at my logs, they used to contain IP addresses.  When the log is emailed to me, the IP address are there.
What setting or filter would stop me from seeing IP address information while looking at my log?
Hope this makes sense
  • Zyxel_James
    Zyxel_James Posts: 788 image  Guru Member
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Hello @Lost1,
    Please make sure the options of source and destination are ticked, thanks.
    James
  • mMontana
    mMontana Posts: 1,437 image  Guru Member
    edited November 2022
    Not that much.
    There were IP addresses in your emailed log and now there are no more?
    There were not IP addresses in your emailed log and now there are?
    Pick one of the two...
  • Lost1
    Here is my question again,
    I don't know when this changed but when looking at my logs (From the Flex 100), they used to contain IP addresses.  When the log is emailed to me, the IP address are there.
    So what I'm trying to say is that when I'm viewing the log, while logged into the FW the logs do NOT show IPs anymore.  The only way I see the email address is after the log is sent to my email.
    Sorry if it was not clear....it was still early :astonished:
    I didn't see anything in the filter that would prevent me from seeing the IP, it's just odd that they are there after it is emailed.
    Thanks!
  • Zyxel_James
    Hello @Lost1,
    James
  • Lost1
    :s I did have those checked.....turns out I just had to shrink my page view and spread out the collums.  It was there, it was just not visible due to my view settings!
    Thanks!  I should have caught that myself!
