How do I enable SNAT for Site2Site IPsec VPN in Nebula
This is USG Flex 200. I found instructions for stand-alone here,but cannot find how to do it in Nebula. It is a necessary feature for the environment. https://mysupport.zyxel.com/hc/en-us/articles/360003321659--ZyWALL-USG-How-to-configure-VPN-SNAT-on-Zyxel-gateways
Hi @Rix,If all USG FLEX devices are managed by nebula, nebula control center will assign different IP subnets for different sites. Hence, you don't need SNAT for site to site IPSec VPN because there is no IP subnet conflict issue. Do you need SNAT feature for Non-Nebula VPN peers?0
Yes. It is non Nebula. I talked to support, not available at this time. Have to factory default and set up in native mode. Or I can change local subnet, or use Lan2 and 2nd Nic in server.0
- 588 USG FLEX H Series
- 477 News and Release
