NWA220AX-6E with USG
bavaria
bavaria Posts: 32 image  Freshman Member
First Comment Friend Collector Seventh Anniversary
does anybody knows if the above AP works with the build-in USg110 controller?
  • Zyxel_HsinBo
    Zyxel_HsinBo Posts: 517 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - WLAN
    edited November 2022
    NWA220AX-6E only support manage in Standalone mode / Nebula Cloud mode, it could not be managed by AP controller (USG110, in your scenario).
    NWA640-6E is the 6E model which could managed by AP Controller, the information is below if you're interested (AP controller support 6GHz after v5.40 firmware):
    Thank you.
    Zyxel_HsinBo
    Untitled Image
  • bavaria
    Hi Zyxel_HsinBo
    Interesting
    on the Swiss Zyxel site, it says:
    https://www.zyxel.ch/de/business-products/wlan-aps-and-controllers/nwa220ax-6e/specifications
    Operating mode
    • Nebula Cloud managed
    • Controller-managed
    • Standalone
    Which is now the correct statement?
    Good that I asked
    Thanks.
  • Zyxel_HsinBo
    The NWA220AX-6E only support Nebula Cloud managed mode and Standalone mode.
    We have moved the website to official link from site created by dealer since September,
    Please refer to the spec sheet of NWA220AX-6E on our official Swiss Zyxel website:
    We're handling your problem cautiously, and revise the wrong information from the original link as soon as possible.
    If you purchased the AP beacuse of incorrect spec sheet info,
    Please contact the original dealer to discuss follow-up matters.
    Sorry for the inconvience.
    Thank you.
    Zyxel_HsinBo
    Untitled Image
Nebula Tips & Tricks
