Does the USG FLEX Series have Port Forwarding problems?
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,350 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @PaoloFracas
    Thanks for your update. Or, you could adjust Egress Bandwidth to 1048576 Kbps and see if it's working for you when you are available.
    And checking whether your wan and lan port speed are 1000M/Full both?
    Thanks.
  • PaoloFracas
    PaoloFracas Posts: 54 image  Ally Member
    I have tried both settings. The one with the line speed and the default one, but nothing change.
  • Zyxel_Jeff
    Hi @PaoloFracas
    Could you collect the complete WAN and LAN interface packet files while you are backup files from the internet to the internal NAS server? BTW, please record the time point that file transmission is unstable.  You can provide the packet files and unstable time points to us via private message. Thanks.
  • PaoloFracas
    I have the logs created on 04/08/2022 (dd/mm/yyyy) and sent to Zyxel but it is 2.09 GB
  • Zyxel_Jeff
    Hi PaoloFracas
    Could you upload the file to a cloud drive and share the downlink with us? Thanks.
  • PaoloFracas
    Zyxel Service is currently setting up a laboratory to perform tests.
    Today I would have to set up a Site to Site VPN to verify that the problem also occurs with this setup.
    I keep you updated.
  • Zyxel_Jeff
    PaoloFracas
    OK, noted! Thanks.
  • PaoloFracas
    I can use WeTransfer but I need an email
  • Zyxel_Jeff
    @PaoloFracas
    You can send it to my e-mail address and I will send a private message to you later.
  • PaoloFracas
    OK
