NSG100 - PPPoE with fixed IP - Impossible???
Peppino
Peppino Posts: 186 image  Master Member
First Comment Friend Collector Eighth Anniversary
I recently ran into an issue where our NSG100 had to be set with fixed IP over a PPPoE connection. Now, this seems to be impossible to set, as the interface settings don't have an option for that.
Was that really left out intentionally? So I have to replace the gateway to something else now?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,532 image  Zyxel Employee
    Hi @Peppino,
    NSG cannot set fixed IP over PPPoE.
    If you want to set this configuration, you can contact your ISP if they can help you fix your IP or replace the NSG with USG FLEX/ATP.
    Zyxel Melen
Nebula Tips & Tricks
