UDP Flood issue (Zywall USG 100)
2»
  • mMontana
    mMontana Posts: 1,441 image  Guru Member
    By chance... uPNP is enabled on the device?
  • follet
    follet Posts: 32 image  Freshman Member
    Thank you for answer. I managed internet suggestions, but I can't find uPNP on my Zyxel Zywall USG100.
  • follet
    I solved this issue!!!
    I appreciate your help and suggestions!
    I just turned ON the checkbox "Firewall" thus, port 53 closed automatically, and the active session pool became in a normal state!
  • mMontana
    Glad you solved. Which "Firewall" checkbox?
  • follet
    Turn ON the firewall at all.
    I even disabled unused rules (like denying UDP packages).
  • mMontana
    :o holy caramel mou!
    I was not seeing that coming!
    That made the world of difference....
