VLAN GS1900-48 VLAN
I have UniFi switches for all my main network but i have a issue adding the CCTV Lan to my Zyxel.
Port 48 is a trunk port and my CCTV and lan is carried from my UniFi switch over to port 48 I would like port5 on the Zyxel as for my CCTV vlan only. Port 5 is untagged and port 48 is tagged for VLAN4 and 48 is a trunk port. I have excluded all other ports from VLAN4 except ports 5 and 48.
But I cannot get my any connectivity on port 5 for my CCTV range. My PVID matches my vlan id from UniFi please can anyone assist on the what i am missing.
This is only a test device before we go live with the it in a production area.
Thanks for everyone's input.
Hi Chris,
Thanks I have solved the issues I was having.0
@JStirHarg,
I assume the connection has failed between the same Vlan or cross Vlan, feel free to correct me if I'm wrong.
And may I know if it's possible to access to Zyxel switch or Ubiquiti sw via VLAN4?
Please collect tech support file and private message me, thanks.0 -
Hi Chris,
- 588 USG FLEX H Series
- 477 News and Release
