Switch POE down.
Hary1987
Hary1987 Posts: 13 image  Freshman Member
 I am using ZyXEL Gs1920-24HP to supply power for the access point.
 However today, the switch cannot supply PoE, but connecting to the computer is OK. Does it mean the switch is failing or what should I check? When I adjust the PoE status, the below error appears:
Error: set PoE Management Extend Configuration fail!
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,496 image  Zyxel Employee
    Hi @Hary1987,
    Could you help to collect Tech support for me to clarify your issue?
    Please go to Menu > Maintenance > tech support > All to collect and PM the tech support file to me.
    Thanks.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Hary1987,
    Could you inactive and activate the PoE function of your port and check if still get this error?
    Please go to Menu > Basic setting > PoE setup > PoE setup to inactive and activate.
    If still get this error, that means the PoE is malfunctioning. please contact your reseller for RMA.
    Zyxel Melen
  • Hary1987
    Hi @Hary1987,
    I checked all setting is OK, and PoE is active. I guess there is a problem with the hardware. I will get the log and send you soon
  • Zyxel_Melen
    Hi @Hary1987,
    Could you also connect your AP to other ports to check if all ports have the same problem or if the problem only occurs on some specific ports?
    And have you connected other PD to this port that also cannot be powered on?
    Zyxel Melen
  • Hary1987
    I have just sent you my config, When I change anything, always that error appears. And no port has the power, I tested all ports.
  • Zyxel_Melen
    Hi @Hary1987,
    Based on your test result, the switch has a hardware issue since it could not provide power on any ports.  Please contact your reseller for the RMA process.
    Zyxel Melen
  • Zhadnost
    Zhadnost Posts: 2 image  Freshman Member
    I'm getting exatly this problem with an XGS2210.
    All PoE devices turned off (phones, a Pi, some CCTV cameras), the APs are on a different switch.
    If I try to turn PoE off on any of the ports I get the same error as above.
    The switch will definitely be out of warranty by now.
    Can this be repaired?
  • Zyxel_Melen
    Hi @Zhadnost
    I suggest contacting our local support team to get more details. Here is an FAQ to contact our local support team in Europe.
    https://support.zyxel.eu/hc/en-us/articles/360002463234-How-do-I-claim-warranty-service-for-my-Zyxel-product-RMA-Process-
    Zyxel Melen
  • Zhadnost
    Thanks for your help
