Strange issue with NWA210AX
I created 3 SSID: A1, A10, A20 with VLAN ID 1, 10, 20. I use pfsense sg-3100. I configured a trunk port with tags 1, 10, 20 on pfsense and NWA210AX uplink is connected to that port. The AP management VLAN ID is 1.
When I connect to A10 or A20 SSID, my MAC cannot obtain IP address. When I try Windows, it gets IP address but cannot connect to DNS. I see DHCP leases in both cases. I tried capturing packets in pfsense and I see DHCP communication, but it seems that response does not reach MAC or Windows.
Now, when I connect to A1 SSID, both MAC and Windows start working right away. AND if I switch to A10 or A20 immediately, they also work and computers get appropriate IP addresses. However, after I connect computer to a different WiFi, it cannot connect to A10 or A20 until I connect it to A1 first.
I tried setting trunk port for tag 1 tagged and untagged changing the management VLAN configuration on NWA210AX with the same result.
Would really appreciate your help.
Thanks!
It seems that I resolved the issue by moving management VLAN ID from 1 to 10. Not sure how that helped. Maybe a conflict with PVID 1 that I think is set on lan1?
I tried setting it "tagged" and "untagged" on both AP and sg-3100 switch. It did not make any difference. I don't think packets were dropped. It looked like maybe ARP issue. Another strange thing was that both Windows and Mac would start working after several minutes.
BTW, running show arp-table only shows MAC addresses associated with management LAN tag. Is it normal?0 -
- 415 Beta Program
- 2.5K Nebula
- 155 Nebula Ideas
- 105 Nebula Status and Incidents
- 5.9K Security
- 319 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.6K Consumer Product
- 256 Service & License
- 398 News and Release
- 86 Security Advisories
- 3.7K FAQ
- 78 Security Highlight
