ZyXEL VPN300 VLAN on MRTG
Hi @phayze,Welcome to the Zyxel community.Is it only the VLAN interface that is not caught?What are your SNMP service control settings?Please capture packet on your VLAN interface to make sure the snmp traffic coming from the MRTG.Where is your MRTG located? on WAN-side or LAN-side?James0
Yes, only VLAN interface not caught. SNMP setting is default. Able to capture all the LAN and LAG interface but not VLAN. MRTG is located on LAN side.
My ZyWALL 110 VLAN is able to be capture by MRTG using same configuration.0 -
Hello @phayze,Did you import the official VPN300 MIB file to the MRTG software? May I check your MIB file? and provide the version of MRTG, thanks.James0
Hello @phayze,As I checked with the MIB browser, it could capture the VLAN interface on VPN300.
Please check on your MRTG, thanks.
James
I was able to see using MIB Browser.
I'm using MRTG ver 2.17.7.
I use "sudo bash –c ‘cfgmaker ZyWALL@192.168.1.1 > /etc/mrtg.cfg’" to generate the mrtg config.
I have no idea what went wrong.0
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
