AP requierement for Zyxel ATP200
auphysch
auphysch Posts: 3 image  Freshman Member
edited May 2024 in Wireless
I have already Zyxel ATP200 device. I want create an Access Point from this device.
On a  eshop i find 2 models i hesitate between us:
Zyxel WAX610D
Zyxel WAC6103D-I
For each of theses i saw that its with Poe+
Do i need to buy anothers equipments (cable, device,etc...) for Poe+ or its integrated in ATP200?
Best Regards,
  • Zyxel_Bella
    Zyxel_Bella Posts: 560 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
    edited November 2022 Answer ✓
    Hi @auphysch
    Would you like to manage the AP by ATP200 or using Nebula Cloud manage mode?
    The WAX610D and WAC6103D-I are able to work at modes mentioned above.
    We’ll recommend the WAX610D rather than WAC6103D-I since it is newer generation with maintaining firmware and more features such as remote AP, NAT and others.
    Both models require 802.3at (PoE+) power, WAX610D needs at least 19W and WAC6103D-I needs 12.48W to service in full power mode.
    You’ll need a PoE switch that can deliver enough power budget on AP’s connected port or a power adapter to provide AP power.
    Thank you
    Regards,
    Bella
  • Zyxel_Bella
    Hi @auphysch
    Thank you
    Regards,
    Bella
  • auphysch
    Hello Bella,
    Thank You so Much for your answer.
