L3 switch: static routing license
Hi @papu,
Since the static routing function is in Switch > configure > IP & routing page which is a pro pack feature, your organization needs to be a pro organization before using it.Zyxel Melen0 -
Thank you for your prompt reply. Not the answer I was hoping for; as static routes should work out of the box for any layer 3 switch.
May I suggest you update the XS1930 documentation with this mandatory annual license requirement.0 -
- 588 USG FLEX H Series
- 477 News and Release
