[Release Note] Small Business Access Point - V6.29 P1 firmware has been released
Small Business Access Point Firmware Release Note
V6.29 Patch 1
NWA50AX V6.29(ABYW.1)
NWA55AXE V6.29(ABZL.1)
NWA90AX V6.29(ACCV.1)
New Feature and Enhancements
1. PSK can be customized per AP basis when Programmable SSID is enabled. (Nebula Pro Pack license is required)
2. Smart Mesh added 3 advanced capabilities – manual uplink, disable downlink, re-connect. (Cloud mode only)
3. Smart Steering added optimization aggressiveness for disassociation.
4. NAT mode is added to NWA50AX/55AXE/90AX. (Cloud mode only)
5. Layer 2 isolation is added to NWA50AX/55AXE; NWA90AX has this already.
Bug Fix
Empty column stands for the mode is unaffected.
Mode |
CLD |
MGNT |
STD |
1. [eITS: 220101169] [Symptom] Local GUI port usage display issue from the path: Monitor >> Network status >> Port Statistics Table >> Switch To Graphic View |
V |
2. [eITS: 220700979] [Symptom] iPhone can’t connect to the SSID automatically, and when tap on SSID, got the incorrect password although password is correct |
V |
V |
3. [eITS: 220800835] [Symptom] AP offline on Nebula and show port 4335 blocked message on local web, when connect to mobile router LAN port |
V |
4. [eITS: 220801383] [Symptom] Once a client disconnected, AP LED will turn into blue light even there are still other clients connected with |
V |
V |
5. [eITS: 221001403] [Symptom] Random restart of APs in a particular scenario |
V |
V |
Known Issue
N/A
Limitation of Settings:
N/A
Zyxel Nebula Support
Why after the firmware upgrade do access points in standalone mode say this on the login page?"Note:
This device is managed by Nebula, please use Nebula assigned password
in the Site-wide > General settings > Device configuration."
- 603 USG FLEX H Series
- 481 News and Release
