L3 switch: static routing license
papu
papu Posts: 23 image  Freshman Member
Question: for a L3 switch e.g. XS1930; can I configure static routing using Nebula base, or do I need pro license for this?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,669 image  Zyxel Employee
    Hi @papu,
    Since the static routing function is in Switch > configure > IP & routing page which is a pro pack feature, your organization needs to be a pro organization before using it.
    Zyxel Melen
  • papu
    Thank you for your prompt reply. Not the answer I was hoping for; as static routes should work out of the box for any layer 3 switch.
    May I suggest you update the XS1930 documentation with this mandatory annual license requirement.
  • Zyxel_Melen
    Hi @papu,
    Thanks for your advice, I will let my team know.
    Zyxel Melen
Nebula Tips & Tricks
