recommendation switch
Network-distributed public amplification audio system.Arenas, stadiums, studio (broadcast or private), conference centers, convention halls, theaters, zoos, themed parks.Name a big place which need specific sound setup, this system should be capable to deliver what you want, where you want and without interference.My question is: 100gbps of switching capability is enough? I'd go a bit bigger.0
hello
here are the recommendations, can the GS series respond to this
Dante uses the UDP protocol for audio distribution, both unicast and multicast. - Bandwidth usage is approximately 6 Mbps per basic unicast audio stream (containing 4 channels and 16 audio samples per channel). Streams are pre-allocated to a capacity of 4 channels. Audio samples can vary between 4 and 64, depending on the latency setting of the device. For multicast streams, there can be between 1 and 8 channels per stream. - The multicast audio stream from Dante devices is always on UDP port 4321. The AES67 multicast audio stream is always on port 5004. - Ports for unicast audio streams vary between: 14336 and 14600. - Audio traffic should not occupy more than 70% of the bandwidth of a network link.u. - Dante devices support sending and receiving Dante multicast streams. Dante multicast uses address range 239.255/16 and port 4321. - Most Dante devices also support sending and receiving RTP multicast (SMPTE 2110-30 or AES67). RTP multicast typically uses port 5004. AES67 typically uses the 239.69/16 address range.- A Dante device can send an RTP multicast stream to any address. - mDNS and DNS-SD protocols are used for discovery and enumeration of other Dante devices (including Dante Controller and Dante Virtual Soundcard) on 224.0.0.251:5353.
- AES67 discovery is on 239.255.255.255:9875. - PTP (Precision Time Protocol) is used for time synchronization. - These are usually a few small packets per second. This traffic is on 224.0.1.129 - 224.0.1.132, ports 319/320. PTP logging (if enabled) is at 239.254.3.3:9998. - Dante-specific traffic monitoring is done on multicast addresses 224.0.0.230 - 224.0.0.233:8700-8708
Hello here are the recommendations for using DANTE at the network level is the GS series able to handle this?
https://www.audinate.com/learning/technical-documentation/so-youre-adding-dante-to-your-network So You're Adding Dante to your Network? | Audinate | Dante Pro AV Networking
hello
here are the recommandations for using dante
is the gs serie is able to handle this ?
Hi @baudetd,
Is your requirement a 48 fiber port 1G switch or a 48 copper port 1G switch with fiber ports?Zyxel Melen0 -
Hi @baudetd,
If you need a 48 copper port 1G switch with fiber ports, then GS2220-50 will fulfill your requirement.
Also, it has IGMP snooping function which allows you to manage the DANTE audio network.
In addition, we have experience with DANTE audio networks, I will PM the configuration to you for reference.Zyxel Melen1 -
@Zyxel_Melen maybe a guideline for "How make Dante work fine with GS2200 series" could be also useful too.
Zyxel_Melen said:Hi @baudetd,
In addition, we have experience with DANTE audio networks, I will PM the configuration to you for reference.0
- 415 Beta Program
- 2.5K Nebula
- 155 Nebula Ideas
- 105 Nebula Status and Incidents
- 5.9K Security
- 320 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.6K Consumer Product
- 256 Service & License
- 398 News and Release
- 86 Security Advisories
- 3.7K FAQ
- 78 Security Highlight
