GS1200-8 vs. VLANs (OPNsense)
Hi everyone, I am fighting with VLAN setup on GS-1200-8 switch. My setup is OPNsense router with VLANs defined and I would like to use GS-1200-8 port 1 as uplink from that router with all VLANs so I setup all VLANs in switch config as tagged on port 1 (including VLAN 1). I would like to use rest of the ports to be a members of specific assigned VLANs but as untagged ports so any device without VLAN knowledge will be able to use it and I thought that this can be done on this switch but it is not working for me. Can you help me please to setup?
nvm... I forgot to setup PVID
strange config interface... 1 -
Hi
I have the same setup & i'm a newbie to this setup. can you please share a step-by-step tutorial as to how to set this up?
this is what i did
1. set a VLAN on OPNSense on interface em1 as Parent (my LAN Interface which is on VLAN ID 1 & also has 192.168.11.x IP Range) with a VLAN Tag of 10
2. Enabled the Interface and gave it a static IP 192.168.5.1/24 and set up DHCP from 100-200
3. In Firewall Rules I enabled all trafficProtocol Source Port Destination Port Gateway Schedule IPv4* * * * * * *
Now on my GS-1900
Port 2 is connected to the em1 Interface from OPNSense
Now this is where i messed up stuff and ended up borking my network and had to reset the switch. Any help in setting up further will be really appreciated0
- 588 USG FLEX H Series
- 476 News and Release
