[Notification] NWA50AX, NWA90AX, NWA55AXE unexpected reboot after firmware upgrade to V6.29P0
Zyxel_Bella
Zyxel_Bella Posts: 620
Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
image  Zyxel Employee
edited May 2024 in Wireless
Issue Description:
The V6.29P0 is temporarily removed due to it has been verified it may cause repeated reboot in worst case scenario. We are investigating this, and we will be providing a fix in highest priority.
Affected Scope:
Models: NWA50AX, NWA90AX, NWA55AXE
Firmware version: V6.29(ABYW.0), V6.29(ACCV.0), V6.29(ABZL.0)
Part of NWA50AX, NWA90AX, NWA55AXE may happen unexpected reboot after upgraded to latest version V6.29P0.
If the user arranged firmware upgrade to stable version, they are immune to the issue.
Solutions:
If your AP has already upgraded and having the same or similar issues, please enable the Zyxel support at Help > Support request > Invite Zyxel support as administrator, save the changes. And provide the Org and Site name with your preferred schedule in the following thread for us to do firmware rollback.
See more details here: [Nebula] How to turn on Zyxel Support Access?
Thank you.
  • iambenmitchell
    iambenmitchell Posts: 7
    image  Freshman Member
    Is there a new version yet? My APs still have their firmware locked so I don’t know if this has been fixed. I like to keep my firmware up-to-date
    thanks
  • Zyxel_HsinBo
    Zyxel_HsinBo Posts: 532
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - WLAN
    We are working on new firmware release progress and expect to release this month.
    I’ll update this post if the release is earlier.
    Thank you.
  • Zyxel_CSO
    Zyxel_CSO Posts: 534
    5 Answers First Comment Friend Collector Ninth Anniversary
    edited November 2022
    The issue is fixed and solution is included in the release firmware 6.29 Patch 1. Please arrange schedule for upgrading. Thank you
    https://community.zyxel.com/en/discussion/15012
    Zyxel Nebula Support
  • GuidoH
    GuidoH Posts: 4
    First Comment Friend Collector SurveyFeedback-2022-Nov Fifth Anniversary
    How do I arrange such a schedule. My NWA50AX does turn itself off after connecting to the network?
  • Zyxel_HsinBo
    The problem has fixed in new release V6.29P1 firmware.
    Now is available on Nebula, you can upgrade the AP from the path below:
    Nebula > Site-wide > Firmware management > Devices
    Find and select your small business model AP, click “Upgrade Now”.
    Or after November 28, you could set up " + Schedule Upgrade" to arrange schedule upgrade time.
    The whole progress from download firmware to upgrade successfully and online on Nebula is about 10-15 minutes.
    Thank you.
  • GuidoH
    GuidoH Posts: 4
    O.k. Thank you for that advice. The status is now "up to date" but it still turns itself off after a reboot. I don't have access to it. Even after a reset to factory settings "I" cannot access it.
    I have granted access via the Help Center in Nebula.
  • GuidoH
    GuidoH Posts: 4
    After some more tests:
    I can get the LED to blink.
    I can Reboot
    I can Logon locally
    I do not see the AP in my WLAN network.
    I cannot configure SSIDs which is actually essential to securely and safely use the AP.
  • Zyxel_HsinBo
    May we know the issue still occurs now?
    Since we see the AP is online on Nebula now, and there is a client connect to NWA50AX record.
    But we found there are 13 "Port 0 is down" logs in past 24 hours,
    Please check the wired Ethernet cables and try change port connect with the upper device to void service impact.
    Thank you.
  • GuidoH
    GuidoH Posts: 4
    @Zyxel_HsinBo
    Thank you, After plugging it in to another port in the switch GS-1900 8HP I could manage the AP and it is working fine now.
