USG 200 WAN with 2 Networks/VLAN
my provider send me some information how to connect by FTTH.
I am using an older USG 200 Security Gateway. I need to connect by pppoe without any vlan id to use internet. I am using wan1. This works great!
To use voip i need to setup a second connection on the same wan interface (wan1) but with vlan id 2222.
How can i setup a second network on the same wan1 interface?
Hi @Maik20,
Did you lost your IP address on wan2_ppp when enable vlan2222 ?
Please kindly share your configuration file by private messages .
Thank you0
Hi @Maik20,
Greeting forum, Please kindly add the VLAN interface with VLAN ID 2222 and base wan1 port.
Then you may test the VOIP connection. Thank you
Kevin0 -
Thanks alot. My phone is currently in lan1did i need an entry in the firewall settings to route vlan2222 to lan1? Later i like to move the phone to vlan400
Hi @Maik20,
In general, just check you have security policy to allow these traffic.
But whether need other settings or not depends on your network architecutre.
Kevin0 -
Thanks for your help!
I have added a vlan2222 on wan2 using dynamic ip. I got an ip from my internet provider on vlan222 10.8.x.x.
But now my internet connection wont work any more. If i disable vlan2222 my internet connection works.
I am using a pppoe connection on wan2 and setup a lan2 (port 3) on the usg2000 to add a voip-fone there.
My provider uses two networks connected over one wan interface:
no vlanid: internet
vlan2222: voip
I think my problem is the routing if i enable the vlan2222
I never setup some special routes. I am using the firewall to restrict access to some vlans i am using for computer, guest, iot. I only have some routes for a vpn connection to our company (COMPANY_LAN). This is my routing table:
Hi @Maik20,
Thank you0 -
Hi @Maik20,
After remove Trunk member vlan2222 internet access works now.
For other problem, please send me the topology by private message/
Thank you
Kevin0
- 588 USG FLEX H Series
- 476 News and Release
