XGS1250-12 LACP & RSTP Support
nitro
nitro Posts: 2 image  Freshman Member
just received my XGS1250-12 devices and found out that LACP & RSTP support is surprisingly lacking.
Are there plans to add support for LACP and Rapid Spanning Tree Protocol (RSTP)?
I also have a GS1900-8 which supports both.
Thanks & best.
  • Zyxel_Chris
    Zyxel_Chris Posts: 739 image  Zyxel Employee
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    XGS1250 is for the soho users, the LAG is the static link, as the request LACP, RSTP with 2.5/10 (multi Giga) is the enterprise level then XS1930 series will fit this case.
  • Zyxel_Chris
    Hello @nitro,
    It's about the product position, our XGS1250 is the entry-level smart managed switch with the basic features compared to the more premium GS1900 series which is for SMB, hope you can understand.  :)
  • nitro
    well what would be an equivalent product offering support for 2.5G / 10G in the SMB segment? Pricing wise I don't understand the positioning of the XGS1250, but I really don't want argue about your product segmentation here :)
    I've read in another thread that there is at least a beta firmware available which offers support for LACP. Can you PM me with the download link?
  • Zyxel_Chris
    Hello @nitro,
    There is a misunderstanding since we only have the datecode to support LAG (static link aggregation) for port 9 and port 10 group, it's not LACP.
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    @Zyxel_Chris the question "what would be an equivalent product offering support for 2.5G / 10G in the SMB segment?" seem still unanswered.
  • Zyxel_Chris
