Bug: DNS no longer delivers internal entries
Hello @baba,
As I checked, your DNS entries still exist now. We're working on the issue, I will let you know when it's fixed, thanks.
James1 -
Hello @baba
The issue is fixed, you're able to add more DNS address records now, please check, thank you.
James0 -
@Zyxel_James today at 2022-12-17 03:30:51 the problem is back without chaning anything (I was sleeping at the time). The internal dns entries will not be resolved anymore. I've saved the diagnostic info
@Zyxel_James Adding and deleting a fake entry fixed it, but that can be a solution. Why the dns entries still disappear suddenly?0
Hello @baba,Do you have the diag-info when the interface DNS entries are not resolved? Please provide it to me via private message, and I will check on this for you, thanks.James0
Hello @babaThe unsolved DNS entry is related to your another discussion thread, it's not the same issue as this subject. Please follow up at My RADIUS Auth via local network does not work, thanks.
James0 -
Hi @Zyxel_James,
that's correct but they hang together. I can not replace the hostname (which will not be resolved suddenly caused by the dns bug) in my SSID with an IP address, because of this bug. When dns entries are not delivered anymore, wifi clients can not connect to their SSID.
Best, baba0 -
Hi @baba,yes, they're the same problem, please let me know if you need anything.0
Hi @Zyxel_James , the error is back. No dns entries will be delivered anymore. Please have a look into my Org/Site.
Best, baba
@baba, we're working on it, please do not add/remove a fake DNS entry just yet.
I will get back to you when there is any progress.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
