ZON useless - no scaling on high res monitors
Hi @AMI
Since the ZON was developed years ago using the native win32 APIs, it did not support high DPI display scale unless it is fully rewritten with a newer UI framework.
Here's the workaround for you to have a better size:
Please right-click the ZON and click "Properties". Go to "Compatibility" and click "Change high DPI settings". Click on Override High DPI Scaling Behavior and choose System (Enhanced) from the drop-down menu.
Then you will get a normal size on ZON.
Zyxel Melen0
Any hints?
Looks like you have to get yourself a secondary monitor with a resolution of 1280x720 (old laptop display) to get the necessary size & resolution to read that application. I know, it is a workaround, not a solution per se.0
I was more like opting for a "hidden" feature to adjust zoom level. Quite frankly, I'd prefer not to go back to the stone age.smb_corp_user said:Looks like you have to get yourself a secondary monitor with a resolution of 1280x720 (old laptop display) to get the necessary size & resolution to read that application. I know, it is a workaround, not a solution per se.0 -
Hi @AMI
Zyxel Melen0 -
Hi and thanks for the Tip, it does work to make it bigger and readable, but becomes a bit sluggish, but i can live with that.
### I am using 4k Monitors since like 10 years. So unless its been written beyond that - its not an excuse.
Besides, there is not much to reprogram - just the window scaling. Thats like 5 clicks and a few lines of code unless the source is really messed up. Assuming its either c++/c#,VB.
Thanks!
- 212 Nebula Ideas
- 550 USG FLEX H Series
- 341 Security Ideas
- 295 Service & License
- 469 News and Release
