IoT on 2.4GHz SSID continuously disconnected
On the events I see a lot of messages like:
Station: c0:49:ef:44:d0:3c left on Channel: 11, SSID: IFAE_IoT, 2.4GHz, Signal: -55dBm, Download/Upload: 342/2734 Bytes, reason 8, Interface: wlan-1-1
I also have some message like:
Station: c0:49:ef:44:d0:3c left on Channel: 4, SSID: IFAE_IoT, 2.4GHz, Signal: -53dBm, Download/Upload: 342/284 Bytes, reason 3, Interface: wlan-1-1
As we are on it, there are also logs like:
Station: C0:49:EF:44:D0:3C has deauth by Auth Timeout on Channel: 11, SSID: IFAE_IoT, 2.4GHz, Signal: -54dBm, Tx/Rx: 0/0 Bytes. reason 2, Interface: wlan-1-1.
What are reasons 8, 3, and 2?
Hi @Otger
For more clearly identify your case, we would like to know more about your SSID settings, ex: security options, 802.11k/v/r status (enable/disable).
You may find it at:
Nebula CC >> Access Point >> Configure >> SSID advanced settings
Please also help me to check for the smart steering status. It is at:
Nebula CC >> Access Point >> Configure >> Radio settings
For the reasons mentioned in your event log, I list its description below:
#2: Previous authentication no longer valid
#3: Deauthenticated because sending STA is leaving (or has left) IBSS or ESS
#8: Disassociated because sending STA is leaving (or has left) BSSYou may find out more reason description on the article here:
Access Point Event Log Reason Code and Descriptions — Zyxel CommunityKay
Kay
Thanks for detailed guide.Zyxel_Kay said:Hi @Otger
You may find it at:
Access Point Event Log Reason Code and Descriptions — Zyxel CommunitybeetvfilmplusKay
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
