NWA50AX IP range assignmnet
Hi @ram1000ro
As NWA50AX is an AP, it doesn’t like the DHCP server will assign AP for its clients. For IP assignment, the AP clients will make request with the DHCP server(ex: router/gateway) in your network.
To make a difference IP range assignment, you may tag your SSID with VLAN ID at Nebula CC >> SSID advanced settings >> Advanced settings >> VLAN ID, and create the VLAN interface at your router/gateway for assigning IP for certain VLAN.
Besides, if there is any switches between your AP and gateway, don’t forget to allow the traffic for the VLAN.
Kay
Kay
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
