Own certificate on GS1920 or GS1900-10HP
BTW: I'm running V4.70(AAZK.1) | 06/17/2021
Hi @Francisco,
XGS2210 series has already supported to import HTTPS certificate from V4.70(AAZ_.0).
The configuration path is Management > Maintenance > Certificates.
Hope it helps.Jason0 -
i've bought the following switch:
GS1900-10HP
But it's still not possible to import own certificates.
I found an article how to import the cert and key via telnet, but this is not working for me with the current firmware.
The switch is useless for me if i can't import my certifcates.
Why is this function not implemented in all smart manged switches?
On Zyxel APs its also possible to generate a CSR and import the Cert.
This is very unprofessional.
It's not even possible to set an hostname for the switch.
Will you provide that in the next updates or is there any other way to import certificates?77
Hi @christ0815,
Thanks for your feedback.
I have helped to add your request to the switch idea section: link
If anyone likes this idea, please feel free to check this idea and leave a comment or click vote.Zyxel Melen0 -
Hi @christ0815, I just noticed that version 2.8 of the firmware of my GS1900-8 was present and it has certificate functionality added. I installed it and it works like a charm. I guess your switch will have the same 2.8 upgrade.
- 434 Beta Program
- 174 Nebula Ideas
- 418 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 269 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 87 Security Highlight
