ZW USG 1100 don't release DHCP adresses
alexey
alexey Posts: 193 image  Master Member
First Comment Friend Collector Eighth Anniversary
DHCP server on USG 1100 don't release ip-addresses
FW 4.71
Lease time set to 5 day. After that pull are full, clients don't get ip.
«13
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 981 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @alexey,
    Please kindly install the latest weekly firmware.
    https://community.zyxel.com/en/discussion/14386/zld-v4-72-wk35-firmware-release#latest
    We have some fixes for the DHCP daemon.
    Thank you
  • alexey
    Hi @alexey,
    Thank you
    No, this FW don't fix problem.
    Today i met this problem again.
  • MarkoD
    MarkoD Posts: 70 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    Perhaps try the latest firmware (4.73)?
  • Zyxel_Kevin
    Hi @alexey
    Please kindly install the latest firmware 4.73 .
    If the issue still , please provide diag-info during issue happen.
    Thank you
    Kevin
  • alexey
    edited January 2023
    Same issue again on 4.73
    Message msg="Cannot find any lease for this client - 11:22:33:44:55:66:77:88, DHCP pool full!" note="DHCP Discover" is syslog
    Send diaginfo to PM
    Router> show version
    Zyxel Communications Corp.
    image number model                            firmware version                                                  build date           boot status
    1            USG1100                          V4.72(AAPK.0)ITS-22WK35-r105124                                   2022-08-31 16:59:40  Standby
    2            USG1100                          V4.73(AAPK.0)                                                     2022-11-18 09:07:49  Running
    PeterUK Posts: 4,411 image  Guru Member
    edited January 2023
    What happens if you set lease to 2 mins?  May be the Zywall does remove IP sooner the shorter the lease?
    Seems there is a bug with V5.35 too on my VPN300 for last access time when that Virtual PC for that IP was long shutdown.
  • alexey
    If i try change current pool - its not helping. Decrease lease, encrease. Nothing. Only disable DHCP server and configure again.
    edited January 2023
    Think the USG 1100 is EOL but I hope they roll out a fix for you.
    AS it is even VPN300 V5.35 has the same bug and I think its the same bug for the old series to do with last access which the old series didn't show and the Zywall is using that to keep the lease alive.
     192.168.255.50 still their. And last access seems to be a copy for all.
    So for me you got DHCP table and then IP/MAC binding in monitor and the two don't link up for last access with IP/MAC binding showing correct and 192.168.255.50 gets removed from listing but DHCP table show a copy all the same last access time plus 192.168.255.50 hangs around.
    After more testing here and will test on a old series here is what is meant to happen
    DHCP table subnet full
    IP lease expires for clients
    I new client what to connect
    Zywall tests a IP that has been expired by ARP to that IP
    If no reply client get IP.
    So maybe you have something making a ARP reply back to Zywall?
