2 port lacp group. How to join with vlan
Hi @khsa,Based on your description, to add the trunk group member to a VLAN is individually add the port number to the specified VLAN.Example:The goal is to add trunk T1 interface 1 & 2 to VLAN 100 member.1. Access to the switch via web GUI.2. Enter the VLAN 100 configuration, fix 1 & 2 port then click "Add".
<b>Note:</b>Check Tx tagging if the connected device could recognize VLAN tagged.
Advanced Application > VLAN > VLAN Configuration.
Hope it helps.
Zyxel_Jonas0 -
As I know, I think you should go on to step 2 now (Advanced Application > VLAN > VLAN Configuration), enter to the created VLAN-s then fixed port 21 & 22.
I've configured my GS2210 this way, too pity there is no option to add the trunk group to a specific VLAN.
Peace!~
J,0 -
Yes I did it. Still no connection. The opposite switch is HPE 1920S 24G I doupted, error is in HP but no. For test I configured one old linksys and hp switches and put together over lacp.Works perfectly. This fact proves, mistake is in zyxel. It seems zyxel too complicated to configure, compare with other vendor switches. Still looking for solution to make zyxel work in lacp0
Hi @khsa,According to the screenshot you provide, it means that Zyxel switch (may I know the model) doesn't receive an LACP packet from the other device, so the "Synchronized ports" is empty & "Aggregator ID" MAC is all "0".LACP protocol allows the switch to negotiate automatically by send/receive LACP packet.To achieve the goal the LACP feature must enable and should have the same link speed on both switches.Is the other device (HPE 1920 24G) LACP is enabled and the link speed is the same?To configure LACP on Zyxel switch only needs 2 procedure.1. Access the switch via Web-GUI then configure LAG first.Advanced Application > Link Aggregation > Link Aggregation Setting
2. Enable LACP.Advanced Application > Link Aggregation > Link Aggregation Setting > LACP
Verification:Success:1. Link aggregation status of synchronized ports and aggregator ID will have values.
2. The port status will be forwarding for port 1 & 2.Status > Port Status
Failed:1. The link aggregation status synchronized ports and aggregator ID are empty and all "0" because the switch does not receive an LACP packet.Application > Link Aggregation
2. The port status will become blocking to prevent LOOP.Status > Port Status
Troubleshooting:1. Check if the LACP in the other device is enabled.2. The speed duplex on both devices must be the same.Hope it helps.Zyxel_Jonas0
- 220 Nebula Ideas
- 602 USG FLEX H Series
- 481 News and Release
