My 1930-28 keeps crashing..
Hi guys,
My switch keeps crashing and I'm not quite sure where to start looking. It hasn't got many active ports. Just 3 10gbe sfps and 1 gige which is connected to another switch. It's been fine for quite a while and I've only recently added it to nebula cloud, it -feels- like ever since that, things have been unreliable .. but it might be a coincidence?
Any debug logs hidden somewhere?
Thanks!
Thanks!
Hi @TonH,
What's your symptom of the crash?
Could you help to log in to the switch GUI and collect the tech support for me to check?
Also, please enable Zyxel support so I can check your event log. Thank.
Go to Help center > Support Request > Zyxel support access enable and save.Zyxel Melen0
Hi @TonH,
Go to Help center > Support Request > Zyxel support access enable and save.Zyxel Melen0 -
Thanks! I've enabled access. Where do I send the logs to?Zyxel_Melen said:Hi @TonH,
Go to Help center > Support Request > Zyxel support access enable and save.0 -
Hi @TonH,
Please send me the tech support and also your org name in the private message. Thanks.
In addition, what are your symptoms of the crash? Could you describe more about it?Zyxel Melen0 -
Hi @TonH,
After checking your tech support, I found that the switch did not have an IP address when it was offline.
Could you change to a static IP address and check if the issue still occurs or not?Zyxel Melen0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
