AP requierement for Zyxel ATP200
            Hi @auphysch Would you like to manage the AP by ATP200 or using Nebula Cloud manage mode? The WAX610D and WAC6103D-I are able to work at modes mentioned above. We’ll recommend the WAX610D rather than WAC6103D-I since it is newer generation with maintaining firmware and more features such as remote AP, NAT and others. Both models require 802.3at (PoE+) power, WAX610D needs at least 19W and WAC6103D-I needs 12.48W to service in full power mode. You’ll need a PoE switch that can deliver enough power budget on AP’s connected port or a power adapter to provide AP power. Thank you Regards, Bella
            Hello Bella,
 Thank You so Much for your answer.0
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 497 USG FLEX H Series
- 323 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
