2.4G and 5G leds remain amber on my Zyxel nwa1123-ac pro even after correct configuration
Hi, so I've configured my zyxel nwa1123-ac pro and it works just fine, absolutely no problem 'till now. Only thing is, the 2.4G led and the 5G led remain amber(instead of green) and I don't understand why, since it works.
I know it might seem trivial, but I would like to know if maybe I've missed something.
Hi @Adrian
The LED showed Amber means the antenna switch is set to "Wall" for the radio.
Would you like to check for your antenna setting?
Physical setting.
Software setting.
The antenna switch in the web configuration has priority over the physical antenna switch after you Enable Software Control as the software setting.
Thanks.
Joslyn5
Hi @Adrian
Physical setting.
Software setting.
Thanks.
Joslyn5 -
Yes, that was it. Thank you very much!0
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 469 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
