Speedtest from router
electsystech
I'd like to see the ability to do an internet speed test from the router for diagnostics.
3
Yes, we do have the plan regarding to this enhancement. Thanks for your suggestion.
How about a UDP speed test?
Hi there, did this ever get implemented? I’d love to run a speed test directly on my router to help troubleshoot network bottlenecks. Thanks! Currently using a usg20-VPN0
I'm also interested.
I use a AX7501-B0
This is now 3 years later. What's the plan for this enhancement?
I have discovered a command related to speed test on the USG60W.
You can try using this command on other models as well, as mentioned in the article.
https://community.zyxel.com/en/discussion/comment/16058#Comment_160580 -
So … still no options in this case ?
- 441 Beta Program
- 293 Service & License
