WAN trunk spill over not working
nacho
nacho Posts: 10 image  Freshman Member
Hello team,
Please i want the correct & confirmed configuration for WAN trunk settlings so that when one ISP link goes down, the other will kick in with out user intervention.
USG1900
Thank you
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 996 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    edited December 2022
    Hi @nacho
    Please kindly check you have enabled ping-check on interface.
    If the issue still please share your config by PM.
    Thank you
    Kevin
  • nacho
    NO i have not, the issue is whenever i enable it, there is still no internet access even when the link comes back online...that is why i am asking for the correct config if i am missing something
  • Zyxel_Kevin
    Hi @nacho
    May we have remote session to check the issue ?
    Please kindly send your available time by private message.
    Thank you
  • USG_User
    USG_User Posts: 400 image  Master Member
    USG110:
    We got two ISP connections in place. But since one of the lines is faster (fiber) than the other (DSL), the fiber line should always be the "active" line and the DSL line should only be used when line 1 fails.
    First setup the ICMP connectivity check (ping) in Configuration > Network > Interface > Ethernet > WAN1:
    We've arranged this connectivity check for WAN1 (fiber line) only.
    And in Configuration > Network > Interface > Trunk you could configure your own trunk configuration:
    with following details:
    When WAN1 fails, the USG is automatically switching-over to WAN2 and an alert report will be sent. When WAN1 is available again, the USG is switching back to WAN1, but unfortunately without any messages to Admins. Works so far.
