How to Connect USG700 to USG310 With Lan cable
NAZ4E
NAZ4E Posts: 9 image  Freshman Member
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 981 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @NAZ4E,
    Thanks for your sharing, You have to add rules to allow traffic.
    For FW-1, src:Z_TPC-to-SPK dst: lan allow
    For FW-2, src:Z_SPK-to-TPC dst: lan allow
    Please kindly check and look forward to your feedback.
    Thank you
  • Zyxel_Kevin
    Hi @NAZ4E
    Please kindly ensure you have routing on both firewalls .
    (USG310:172.16.1.0/24 next-hop 172.16.99.1)
    (Flex700: 192.168.5.0/24 next-hop 172.16.99.2)
    Then you can connect to FLEX and USG at both sites.
    Thank you
    Kevin
  • NAZ4E
    yes,i did it.but i can't ping 172.16.99.1 to 172.16.99.2 or 172.16.99.2 to 172.16.99.1
    GE0/12 and GE0/8 Config interface type internal or external?
  • Zyxel_Kevin
    Hi @NAZ4E,
    Please choose interface type "internal" for 172.16.99.0/30.
    kindly share your configuration files by private messages.
    I will do the check as well.
    Thank you
    Kevin
  • NAZ4E
     Ok. I did it. but Can't Ping
    PeterUK Posts: 4,415 image  Guru Member
    edited December 2022
    To ping each interfaces you need a rule from Z_TPC-to-SPK to Zywall and from Z_SPK-to-TPC to Zywall for ICMP.
    Remove the static route rule
    Then you need a routing rule.
    Incoming LAN
    Source address 192.168.5.0/24
    destination address 172.16.1.0/24
    next hop gateway 172.16.99.1
    SNAT none
    on the other side
    Incoming LAN
    Source address 172.16.1.0/24
    destination address 192.168.5.0/24
    next hop gateway 172.16.99.2
    SNAT none
    Then firewall rule
    from LAN to Z_TPC-to-SPK and from LAN to Z_SPK-to-TPC.
  • NAZ4E
      ok. i configuration follow with you but can't conneted.
  • Zyxel_Kevin
    Hi @NAZ4E
    I feel a little confuse, because the screenshots are not matched with your topology.
    Please share the configuration files by private message
    And kindly describe what is your purpose? (what IP address should be accessed from X.X.X.X) It will be clear.
    Thank you
  • NAZ4E
    I want the two buildings to be connected.
    TPC building can access time attendance and SPK building can access File Server.
  • Zyxel_Kevin
    Hi @NAZ4E,
    Thank you
