L2TP VPN Active Directory authentication do not work
Sébastien
Sébastien Posts: 41 image  Freshman Member
Hi everyone,
I'm trying to set up an L2TP/IPSec VPN with AD authentication but it does not work because my user is rejected. The appliance is a USG Flex 100 managed by Nebula.
First of all, I add my AD to Nebula
And I configure the VPN server with my AD for authentication
Then I add a test user to my AD users
And finally, here is the log when trying to connect to this VPN
It's really surprising because I'm 200% hundred sure of the username and password.
Am i doing something wrong ? Please also note that the USG Flex is correctly added to my AD in the "Computers" section.
Should I configure something else on my AD ? NPS maybe ? Or should the user be added to a specific group ?
Thanks,
Sebastien
  • Zyxel_James
    Zyxel_James Posts: 788 image  Guru Member
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Please confirm the account could be queried by your firewall. Connect to console port and input
    "_debug domain-auth test profile-name example.profile.name username example.username password example.password".
    Moreover, please provide org/site to me via private message, and enable Zyxel support access, you can find it at Help > Support Request > Zyxel support access, enable zyxel support. I would like to check on your device, thank you.
    James
  • Sébastien
    Dear James,
    I have tried the command using a SSH connection to the router, and the answer is :
    % Get AD group VDC has failed
    retval = -24004
    ERROR: Display AAA group has failed.
    Where VDC is the name of my AD configuration in Nebula.
    What does this mean ?
    Thanks,
    Sébastien
  • Zyxel_James
    Hi @Sébastien, I have contacted you via PM, please check your inbox, thank you.
    James
Nebula Tips & Tricks
