Own certificate on GS1920 or GS1900-10HP
13»
  • Francisco
    Francisco Posts: 6 image  Freshman Member
    BTW: I'm running V4.70(AAZK.1) | 06/17/2021
  • Zyxel_Jason
    Zyxel_Jason Posts: 429 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Hi @Francisco,
    XGS2210 series has already supported to import HTTPS certificate from V4.70(AAZ_.0).
    The configuration path is Management > Maintenance > Certificates.
    Hope it helps.
    Jason
  • christ0815
    christ0815 Posts: 1 image  Freshman Member
    edited December 2022
    i've bought the following switch:
    GS1900-10HP
    But it's still not possible to import own certificates.
    I found an article how to import the cert and key via telnet, but this is not working for me with the current firmware.
    The switch is useless for me if i can't import my certifcates.
    Why is this function not implemented in all smart manged switches?
    On Zyxel APs its also possible to generate a CSR and import the Cert.
    This is very unprofessional.
    It's not even possible to set an hostname for the switch.
    Will you provide that in the next updates or is there any other way to import certificates?77
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,531 image  Zyxel Employee
    Hi @christ0815,
    Thanks for your feedback.
    I have helped to add your request to the switch idea section: link
    If anyone likes this idea, please feel free to check this idea and leave a comment or click vote.  =)
    Zyxel Melen
  • Hi @christ0815, I just noticed that version 2.8 of the firmware of my GS1900-8 was present and it has certificate functionality added. I installed it and it works like a charm. I guess your switch will have the same 2.8 upgrade.
