Zyxel GS2200-24 L2 Manageable Switch Firmware
sancharstrike
in Switch
Is Zyxel GS2200-24 L2 Manageable Switch Firmware available or not?
What is the EOL date of this product?
RMA or hardware replacement request can generate or not?
May I request RMA for Zyxel GS2200-24 right now?
Hi @sancharstrike,
The EOL date of GS2200-24 is 2017/1/31.
Do you need the firmware because your switch cannot boot up?
In addition, the suggested replacement switch is GS2220-28.Zyxel Melen0 -
Hi @sancharstrikesancharstrike said:May I request RMA for Zyxel GS2200-24 right now?
Since GS2200-24 has been EOL for a long time, the RMA service is no longer supported.Zyxel Melen0 -
I need firmware for Zyxel GS2200-24 because it can't boot up. Also as it won't boot, how will I load firmware?
Here is telnet debug messages:
Copyright (c) 1994 - 2011 ZyXEL sysExceptionHandler: sysTaskId()=[0x812F51B0], n ame=[PINI]
Exception occured!EPC= 0x8014EDE4SR= 0x00007F03CR= 0x50808008$RA= 0x03E00008TLBL
Abnormal Stack Task List : NONE/cygdrive/d/Source/400GS220024preb5/400GS220024b5/src/../src/sys_isrdep.c:185 sy sreset()
Thank you, problem solved!0
- 433 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 115 Nebula Status and Incidents
- 6K Security
- 388 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 4K FAQ
- 83 Security Highlight
