Blocking torrents
TAPTech
TAPTech Posts: 174 image  Master Member
First Comment Friend Collector Seventh Anniversary Nebula Gratitude
Here in the USA, the ISP's will often send notices if they detect that movies are being downloaded (typically via torrents) and threaten to terminate service.
Currently I'm using both content filtering and Application Patrol to block P2P and Torrent sites.
For Content Filtering:  P2P Sites, and Usenet Sites.
For Application Filtering: The entire P2P category.
It does seem a bit heavy-handed though, when viewing the logs.  Has anyone developed a good list of items to block, that they wouldn't mind sharing?
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,370 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    edited December 2022 Answer ✓
    Hi @TAPTech
    Yes, it indeed can provide protection for you.
    Content filter categories:
    Application patrol profile for P2P related programs.
    You could select a specific category(such as application patrol) and time range to filter the search result of the event log, which could make it easier and clearer to find the logs that you want.
    Besides, we encourage you could use SecuReporter to check the detailed traffic statistics as well.
     Thanks.
  • Zyxel_Jeff
    Hi @TAPTech
     Thanks.
Nebula Tips & Tricks
