Quick HowTo for a VPN Connection to a Phone and W10?
Username_is_reserved
in Security
Hi
Can someone recommend a HowTo for a VPN with a ATP from a Phone and W10 Client?
Look for L2TP.
In Quick Setup > Remote Access VPN Setup, select one of the scenario to configure remote access VPN on wizard.
L2TP VPNHow to setup L2TP VPN for remote access
Note: Android 12 and later versions do not support L2TP VPN. Please use IKEv2 instead.IKEv21 -
So I try to make the VPN Connection but I always get the error:
1 2022-12-21 22:08:38 info IKE The cookie pair is : 0x1274635555208d3c / 0xac26bcad3e72b10a [count=3] YYY.YYY.245.53:500 ZZZ.ZZZ.220.28:500 IKE_LOG<br>2 2022-12-21 22:08:38 info IKE The cookie pair is : 0xac26bcad3e72b10a / 0x1274635555208d3c [count=2] ZZZ.ZZZ.220.28:500 YYY.YYY.245.53:500 IKE_LOG<br>3 2022-12-21 22:08:37 info IKE The cookie pair is : 0x1274635555208d3c / 0xfe82223f7b4d520f [count=3] YYY.YYY.245.53:500 ZZZ.ZZZ.220.28:500 IKE_LOG<br>4 2022-12-21 22:08:37 info IKE The cookie pair is : 0xfe82223f7b4d520f / 0x1274635555208d3c [count=2] ZZZ.ZZZ.220.28:500 YYY.YYY.245.53:500 IKE_LOG<br>5 ...<br>6 2022-12-21 22:08:36 info IKE IKE SA [] is disconnected [count=3] YYY.YYY.245.53:500 ZZZ.ZZZ.220.28:500 IKE_LOG<br>7 2022-12-21 22:08:36 info IKE Send:[NOTIFY:INVALID_MAJOR_VERSION] YYY.YYY.245.53:500 ZZZ.ZZZ.220.28:500 IKE_LOG<br>8 2022-12-21 22:08:36 info IKE The cookie pair is : 0x1274635555208d3c / 0x345ebc7c96200639 YYY.YYY.245.53:500 ZZZ.ZZZ.220.28:500 IKE_LOG<br>9 2022-12-21 22:08:36 info IKE Major version numbers are different ZZZ.ZZZ.220.28:500 YYY.YYY.245.53:500 IKE_LOG<br>10 2022-12-21 22:08:36 info IKE The cookie pair is : 0x345ebc7c96200639 / 0x1274635555208d3c ZZZ.ZZZ.220.28:500 YYY.YYY.245.53:500 IKE_LOG<br>11 2022-12-21 22:08:36 info IKE Recv Main Mode request from [ZZZ.ZZZ.220.28] ZZZ.ZZZ.220.28:500 YYY.YYY.245.53:500 IKE_LOG<br>12 2022-12-21 22:08:36 info IKE The cookie pair is : 0x1274635555208d3c / 0x0000000000000000 ZZZ.ZZZ.220.28:500 YYY.YYY.245.53:500 IKE_LOG<br>13 2022-12-21 22:08:36 info IKE [SA] : No proposal chosen [count=3] YYY.YYY.245.53:500 ZZZ.ZZZ.220.28:500 IKE_LOG<br>14 2022-12-21 22:08:36 info IKE [SA] : Tunnel [RemoteAccess_L2TP_Wiz] Phase 1 proposal mismatch [count=3] YYY.YYY.245.53:500 ZZZ.ZZZ.220.28:500 IKE_LOG<br>15 2022-12-21 22:08:36 info IKE The cookie pair is : 0x1274635555208d3c / 0x8258c8e74d93acb9 [count=3] YYY.YYY.245.53:500 ZZZ.ZZZ.220.28:500 IKE_LOG<br>16 2022-12-21 22:08:36 info IKE Recv IKE sa: SA([0] protocol = IKE (1), 3DES, HMAC-SHA1-96, HMAC-SHA1 PRF, 1024 bit MODP; [1] protocol = IKE (1), 3DES, HMAC-SHA256-128, HMAC-SHA256 PRF, 1024 bit MODP; [2] protocol = IKE (1), 3DES, HMAC-SHA384-192, HMAC-SHA384 PRF, 1024 bit MODP; ). [count=3] ZZZ.ZZZ.220.28:500 YYY.YYY.245.53:500 IKE_LOG<br>17 2022-12-21 22:08:36 info IKE [INIT] Recv: [SA][KE][NONCE][NOTIFY][NOTIFY][NOTIFY][VID][VID][VID][VID] [count=3] ZZZ.ZZZ.220.28:500 YYY.YYY.245.53:500 IKE_LOG<br>18 2022-12-21 22:08:36 info IKE Receiving IKEv2 request [count=3] ZZZ.ZZZ.220.28:500 YYY.YYY.245.53:500 IKE_LOG<br>19 2022-12-21 22:08:36 info IKE The cookie pair is : 0x8258c8e74d93acb9 / 0x1274635555208d3c [count=2] ZZZ.ZZZ.220.28:500 YYY.YYY.245.53:500 IKE_LOG
That do I wrong? Thanks
In the log, it shows [RemoteAccess_L2TP_Wiz] Phase 1 proposal mismatch. Please check VPN Gateway Phase 1 Settings. ATP and L2TP VPN client must use the same Encryption, Authentication method, DH key group and ID Type/Content to establish the IKE SA. Besides, you can also check the IKE version. If you're using L2TP VPN, use IKEv1. If your client is Andriod phones with Android 12 and later versions, it doesn't support L2TP VPN. Please select IKEv2 scenario.If it is still not working, please send the remote access information of your ATP and one L2TP VPN account/password to me in private message.0
Thanks for replay I export the Settings to Win10 and Import them via the Batch File. It seem the Import worked. Do I have to change anything in Win or the ATP after them?
Just click on the .bat file and the setting will be configured automatically on Windows 10. Click "Connect" and enter the username and password. L2TP VPN is connected.
sry I did an mistake and now it works on my Win10 Tablet.How to add them Manually on my W7 Machine?Thanks0
You can follow the steps in these two articles to set up L2TP VPN on Windows 7.1
- 244 Nebula Ideas
- 6.9K Security
- 808 USG FLEX H Series
- 392 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
