Modem only VMG8825-T50 & ASUS RT-AX88U Router
flunky
flunky Posts: 1 image  Freshman Member
edited December 2022 in Smart Home Product
Hello everyone.
I've just had fibre installed with VoIP and been given a VMG8825-T50. I previously was using a very old Virgin Media router with the amazing ASUS RT-AX88U.    I've accessed the admin console and change the VMG8825 vdsl to bridge and turned off the firewall as per the online instructions. This did pass ethernet to the Asus but I could not access the Asus at all to set it up as the new wifi and ethernet router.   Wifi was still active on the VMG8825.
I only need the VMG8825 to be a bridge and keep the VoIP service active.
What do I need to do?
Thanks in advance.
  • eyezopen
    eyezopen Posts: 1 image  Freshman Member
    heya, i need this exact advice - did you manage to get anywhere?
