[NEBULA] NSG50 L2TP VPN port failed
Hi @MatthieuWelcome to Nebula community!!Do you mean you can ping your phone (Autocom) but cannot connect it and also got trouble on UDP 69 of TFTP service (but can access it with HTTP?)Also, may I know what's your phone software service using(TCP/UDP or multicast)? Please share your scenario for us.
hi
the problem
i can connect to autocom with http and ping
but when alcatel lucent soft phone want to connect he said connection failed
and in the autocom log i can read failed connect with the ip adresse 192.168.0.1 but it's the firewall adress and not the client adress
the autocom don't receve the good adress
and i don't understand why
firewall adress 192.168.0.1
autocom adress 192.168.0.246
client adress 192.168.4.10 -
Hi @Matthieu
The reason of this problem is because of our L2TP will auto create the policy route for outgoing traffic (to Internet) hence it will use the SNAT, I'll suggest to add the policy route to resolve this issue as following screenshot, navigate to the Gateway>Configure>Policy route
The select the type as "intranet traffic" the source IP will be your client and the destination will be the server IP. Hope it can help
cheers!
thanks for the answers
i want to test but
in my admin web site i don't have the same page
Hello @Matthieu
Please be aware that the policy route type is "Intranet Traffic"0 -
thanks a lot it's ok
- 441 Beta Program
- 210 Nebula Ideas
- 538 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
