Why can't my router update?
VengefulRat
in Home Router
I followed the links given in a different discussion hoping I can update the router. Nope, got stuck at the same place as where he was stuck since no one came back. So how do I update the router? Because right now, this router is utterly atrocious. Nothing works right.
What is your model of the router?
You can describe more details so the people here can help you if they have encounter the same experience.0 -
https://community.zyxel.com/en/discussion/13192/how-do-i-upgrade-the-firmware-for-emg3525-t50bikubuf said:What is your model of the router?
Wasn't sure if anyone would actually reply to the discussion. But the thread above is what I'm mentioning towards. My router is the exact same as that. I have the exact same issue and as you can see, there is no solution given to the issue. So instead of asking how to update, I'm more curious as to why it can't be updated since it seems an update can't be done.
- 588 USG FLEX H Series
- 477 News and Release
