NWA210AX - Secondary SSID - WPA2 PSK - intermittently fails auth
Firmware: V6.45(ABTD.0) (Latest)
My secondary network (guest) which is 2.4ghz only, and set to vlan 999 goes through periods of not authenticating clients with the pre shared key. I see my clients go offline and when trying to re-authenticate i get password incorrect.
Via Nebula I've tired to change the name of the SSID / Pre shared key, but no joy same problem password incorrect, i see the network name change but the password is not accepted.
My primary SSID which is 2.4ghz and 5ghz, has no issues whatsoever.
This usually lasts for about 30mins and it just starts working again.
Any ideas?
Any ideas?
Hi @saqib_s,I'm glad to hear that your issue has been resolved. We have now set the DCS to skip channels 1 and 2, so the AP will not change to those channels. You can keep this configuration, or if you find the noise-generating device in the future, you can adjust the DCS setting againJay0
Hi @ saqib_sLet us clarify the situation. Your guest used your guest’s SSID for a while. And your clients go offline. When trying to re-authenticate, you got the password incorrect.Because your SSIDs are different from 2.4G only and 2.4G&5G, could you share with us why you only want to let the guest use 2.4G?And if you don't mind, please help us enable the 5G and test the issue if it still happens.And please help us adjust the radio setting.1. Adjust the 2.4G output power to 15dBm. This is used to let the station hear 5G first. Since the station will try to roam if the signal gap is over 5dBm. So jsut reduce the 2.4G output power to ensure the station can hear 5G signal first.2. Adjust the channel width as 20MHz for each radio. This is used to reduce the co-channel interference.3. (Optional) To ensure the AP can have the best channel for the day, we suggest toa. enable DCS schedule to let AP choose better channel for the dayb. disable "DCS client aware" to let the AP jump to the better channel when the DCS worksc. disable "Avoid 5G DFS channel" to let the AP have more options.You can refer to this article.About the station,do all of your guests’ stations have this issue or does only one model station has this issue like an iPhone?1. Check if new driver is available for the station and install the latest version.2. Fine-tune the deployment of AP's location. The client connects the signal recommended –70dBm or above.If it still can’t solve the issue by adjusting the radio setting and AP deploymentCould you share one of the device mac addresses that the guest can’t access the authentication? And please help us activate the Zyxel Support in the below path.(Help>Support Request). We can observe the log afer that.ThanksJay0
Hi Jay,
Thanks for the help, I made these changes and it did not seem to help.
Last night the issue occurred again and did not resolve until I rebooted the AP. All 2.4ghz connectivity was lost, regardless of the SSID. 2.4ghz devices when trying to connect show an unable to access message.
I've activated support from Help -? Request support
See event log below.
We saw that the 2.4G utilization was too high on 12/09.
It could affect your 2.4G device usage.
We suggest that you can adjust the 2.4 GHz channel deployment to “All available channels”
And if you have the same problem in the future, please don’t reboot the AP at the first time. Please help us collect the AP diaginfo at AP web GUI. Please use your browser to https://AP IP(for example: https:172.22.xx.x).
Login in GUI.
User : admin
Password: (site-wide password)
Follow the path below to verify your site-wide admin-password:
Website Left sidebar > Site-wide > Configure > General settings > Device configuration > Local credentials > Password
And go to Maintenance > diagnostics > collect now
Jay
Hi Jay,
I made the change to all channels, not sure this has helped. this issue has occurred again just now, at 09:09 am EST. (UTC +5)
I've collected the diagnostic logs and will send you a message on here with the file.0 -
Hi @saqib_s
Thanks for your feedback. We've noticed that channels 1 and 2 are still experiencing noise issues. Can you let us know where your access points are currently located? We suggest placing them in the middle of the ceiling in areas where you often use 2.4 GHz devices. This will improve the performance of your wireless network. Furthermore, we can help you block channels 1 and 2 to optimize your 2.4 GHz usage.
Jay
Thanks Jay, the AP is located on the ceiling mounted in the middle so not susceptible to much noise.
How do i block channel 1 & 2 ?0 -
Hi @saqib_s
We help us set up the manual DCS and skip channels 1 and 2.
We saw that your AP was on channel 8 yesterday.
Please help us check if 2.4G devices have the same issue.
On the other hand, channel 1 and channel 2 have a lot of noise, you can check if there is a microwave near the 2.4G devices or some interruptions on the floor.
Jay0 -
There aren't any regular devcies, we have a microwave but its far away from the AP and devices.
I've had not issues over the last 2-3 days, so perhaps using channel 8/9 might be better, should I change this for the AP?0 -
- 385 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 74 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 886 Nebula FAQ
- 415 Security FAQ
- 228 Switch FAQ
- 199 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 63 Security Highlight
