Issue when printing
Following VLAN deployement, I'm currently encountering printing issue.
Indeed, on any PCs, jobs stay stucked in spool and are not delivered to printer. The only thing to do is to leave jobs in spool and restart the computer. Once the computer is restarted, jobs are sent to printer.
Below, a diagram of my architecture:
Actual status and tests:
* Any PCs on the same switch, same VLAN, same OS can print and others not. As an example, in our diagram PC01 can but PC02 can't.
* Every PCs can ping printer and access to its web interface configuration.
*As I previously said, when we restart the computer, jobs in spool are sent to printer
* I've tried to disable SNMP check in printer configuration on PCs because printer was seen as disconnected
*I've also tried to disable bidirectionnal mode in printer configuration on PCs
*Print works well when I'm on the same subnetwork (connect to the non manageable switch)
* Below packet trace of a KO printing job
*Below packet trace of an OK printing job
Thanks for your help!
Seb
The problem was caused by our antivirus/firewall solution which refused network printing.
The installer let the user choose if he want to use windows firewall or bitdefender firewall that's why some users were able to print and others no.
Thanks for your help.
Seb.
Hi @drouboyboy
I will send you private message for check this issue more detail.
Seb.
- 3K Nebula
- 228 Nebula Ideas
- 130 Nebula Status and Incidents
- 6.6K Security
- 643 USG FLEX H Series
- 357 Security Ideas
- 86 Switch Ideas
- 54 Wireless Ideas
- 303 Service & License
- 496 News and Release
- 93 Security Advisories
- 4.9K FAQ
- 89 About Community
- 110 Security Highlight
