USG Flex with Nebula and iptables masquerade
baba
baba Posts: 280 image  Master Member
edited December 2022 in Nebula
Hi all,
is it possible to use iptables with an USG Flex 200 and Nebula?
iptables -t nat -A POSTROUTING -s 10.10.20.100 -d 10.10.30.100 -j MASQUERADE
My vacuum cleaner Roborock S7 does not respond when client is not in the same subnet/vlan.
CLI would be also ok for me if it is permanent :-)
Thanks!
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    edited December 2022 Answer ✓
    Hello @baba
    Thanks for sharing captured packets with us. we noticed there is only one-way direction from vlan10 to vlan 30.  The 10.10.30.X didn't respond to the initiated host 10.10.10.X host IP, not sure if it is a limitation for the vacuum cleaner, I mean the vacuum cleaner seems to only respond to the source IP which is from the same subnet.
    IP Client 1 (Server): 10.10.10.X (vlan 10)
    IP Client 2 (Xiaomi Roborock S7): 10.10.30.X (vlan30)
    Port 54321 Protocol UDP
    Currently, we don't support this similar SNAT behavior just like the masquerade function, thanks again.
  • lalaland
    lalaland Posts: 91 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    Do you mean that phone APP and  Roborock S7 must in same subnet for connection?
  • Zyxel_Jeff
    Hi @baba,
    Could you share your topology, usage scenario, and purpose with us?
    It's more clear to understand your requirement. Thanks.
  • baba
    @lalaland yes correctly. The Roborock API is only accessible within the same subnet.
    @Zyxel_Jeff
    Purpose: The API of the vaccuum cleaner "Xiaomi Roborock S7" is not accessible from other subnets.
    Usage scenario: I want to connect to the api at 10.10.30.100:54321/udp (Client 2) from another subnet (Client 1).
    Topology: USG Flex 200 -> NWA110AX -> Client 1: Server 10.10.20.100 (vlan20), Client 2: Roborock 10.10.30.100 (vlan30)
    Do you need any other information?
    Best, baba
  • Zyxel_Jeff
    Hello @baba
    Could you enable Zyxel support for us(as below) and then tell us your org and site name via private message? We would like to check your settings, thanks.
  • Zyxel_Jeff
    baba said:
    Hi all,
    Hi @baba
    Currently, we don't support this feature, thanks.
  • Zyxel_Jeff
    Hello @baba
Nebula Tips & Tricks
