XGS2210-52 Change IGMP Query Interval via CLI
bseiz
bseiz Posts: 5
Hi there,
we have a XGS210-52 switch.
We want to alter the IGMP querier interval.
For now the general queries are sent each 125 s. We checked with Wireshark.
In the web UI there is no parameter available.
We checked the CLI documentation.
To read out the actual value the command
  show ip igmp timer
returns
   Invalid commant "igmp"
Trying to start the configuration with
  ip igmp query-interval <1-65535>
fails.
Entering config mode with
  configure
  router igmp
returns
  No callback for "igmp"
Can someone point out how to read the value and how to configure it?
Kind Regards
Bernhard
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,027 image  Guru Member
    Hi @bseiz,
    Welcome to the Zyxel community!
    Sorry, the XGS2210 could not change the IGMP querier interval time.
    Could you share your scenario of why you need to change the IGMP querier interval?
    Zyxel Melen
  • Zyxel_Melen
    Hi @bseiz,
    Zyxel Melen
  • bseiz
    bseiz Posts: 5
    Dear Melen,
    thank you for your response!
    We are developing devices for the broadcast segment and a have some applications using multicast.
    For development test environments a shorter querier interval would be nice. We use normally 30s instead of 125s. It speeds up testing multiple scenarios.
    We have also some GS1900-24(E) switches where the interval can be setup via UI.
    Therefore we wondered why the much bigger XGS2210 does not offer this.
    Kind Regards
    Bernhard
  • Zyxel_Melen
    Hi @bseiz,
    Thanks for your feedback.
    I will confirm it with my team and keep you posted.
    Zyxel Melen
  • Zyxel_Melen
    Hi @bseiz,
    Sorry for the late response.
    XGS2210 does not have a query interval time setting because it has Fast leave and immediate leave settings for IGMP snooping.
    In addition, I have helped to create an idea post (link). You could leave your comments there and give it a vote.
    Zyxel Melen
