Bug: DNS no longer delivers internal entries
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Hello @baba,
    As I checked, your DNS entries still exist now. We're working on the issue, I will let you know when it's fixed, thanks.
    James
  • Zyxel_James
    Hello @baba
    The issue is fixed, you're able to add more DNS address records now, please check, thank you.
    James
  • baba
    baba Posts: 280 image  Master Member
    @Zyxel_James today at 2022-12-17 03:30:51 the problem is back without chaning anything (I was sleeping at the time). The internal dns entries will not be resolved anymore. I've saved the diagnostic info
  • baba
    @Zyxel_James Adding and deleting a fake entry fixed it, but that can be a solution. Why the dns entries still disappear suddenly?
  • Zyxel_James
    Hello @baba,
    Do you have the diag-info when the interface DNS entries are not resolved? Please provide it to me via private message, and I will check on this for you, thanks.
    James
  • Zyxel_James
    Hello @baba
    The unsolved DNS entry is related to your another discussion thread, it's not the same issue as this subject. Please follow up at My RADIUS Auth via local network does not work, thanks.
    James
  • baba
    edited December 2022
    Hi @Zyxel_James,
    that's correct but they hang together. I can not replace the hostname (which will not be resolved suddenly caused by the dns bug) in my SSID with an IP address, because of this bug. When dns entries are not delivered anymore, wifi clients can not connect to their SSID.
    Best, baba
  • Zyxel_James
    Hi @baba,
    yes, they're the same problem, please let me know if you need anything.
  • baba
    Hi @Zyxel_James , the error is back. No dns entries will be delivered anymore. Please have a look into my Org/Site.
    Best, baba
  • Zyxel_James
    @baba, we're working on it, please do not add/remove a fake DNS entry just yet.
    I will get back to you when there is any progress.
Nebula Tips & Tricks
