FttP only getting 80Mbps download for 250/25 link - Zyxel ZyWall USG100 Plus
Just tested this, and in our case it is disabling "Interface Traffic Statistics" ensures Collect Statistics is not re-enabled. We can happily leave "Reset counters after sending report successfully" enabled.Zyxel_Cooldia said:Hi @AWUSupport,
Please disable "Reset counters after sending report successfully" in daily report setting.
It will auto tick if reset counter is enable in daily report.
CONFIGURATION > Log & Report > Email Daily Report.
Give it a try and see if this works for you.0
- 588 USG FLEX H Series
- 477 News and Release
