MG-108 upload speed are limited to <400MPS
weitehuang
in Switch
I am testing the 5G CPE on their mmWave throughput. I need to compare the performance on different PCs. When I use MG-108 the DL speed is perfect. But UL speed only 300+ MPS. My ISP has symmetric traffic flow which support 1G DL/UL. My connection is below:
1. ISP -> MG-108 -> PC
2. ISP -> PC
Test results are below:
1. DL 900 UL 300
2. DL 900 UL 900
I purchased 2 MG-108 and they behaved the same way. Any idea?
Thanks!
Weite
2. ISP -> PC
1. DL 900 UL 300
2. DL 900 UL 900
Thanks!
Weite
Hi @weitehuang,
We have experienced some upload decrease cases and solved them by disabling the Green Ethernet Technology (EEE).
Could you share your MG-108's serial number and the modem's model name with me?
Or could you check if your modem supports the EEE function? If yes, could you disable it and test again?
Zyxel Melen0 -
Hi Melen,
Thanks for quick response! Here are my S/N
1. S224324007867
2. S224324007861
My modem is a fiber optic modem (model BGW210 from AT&T/Arris). I browsed the settings but didn't see EEE is supported. Appreciate your help!
Thanks!
Weite0 -
Hi @weitehuang,
Sorry for the late reply and thanks for your information.
I will pm you for asking for your contact information so our local support will contact you.
Zyxel Melen0
- 588 USG FLEX H Series
- 476 News and Release
