XS1930 Error: Add policy rule failed!
Hi @amash,
Could you share what rule did you add and the tech support?
Please go to Management > Maintainece > tech support > all to download.
I will try replicating it and check tech support's event log.Zyxel Melen0 -
Hi @Zyxel_Melen
Classifier Configuration
Policy
total Classifier - 58total rules -9
Adding to the current rule also does not give
tech support contains the entire configuration, so I will not be able to transmit it in an open form for everyone0 -
Hi @amash,
I configure the classifier and policy you provide on my XS1930-10 V4.70 patch4 but there's no error message.
In order to check the full configuration and the event log to clarify your problem, could you send the tech support to me in a private message? So your configuration will not be opened by others.Zyxel Melen0 -
Hi @amash,
Good day.
If you have any reservations about sharing your tech support information with me, could you provide me with a list of your ACL settings so I can better understand the situation?
Thanks.Zyxel Melen0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
